Cell selection by macro
bpeirson
CA
I have a macro which selectas a predefined set of rows on a worksheet. I would like to know how to have this macro select only those rows appearing above the first empty row or above the row with a certain value in column A.
Any tips are appreciated.
Try the following, this looks at cell D4 for a value and then looks down column A for the first occurence and selects all the rows above.
targetvalue = Cells(1, 4).Value
endrow = Columns("A:A").Find(targetvalue).Row
Rows("1:" & endrow).Select
If you define a name (Ctrl-F3), for example MyRange, as:
=OFFSET(Sheet1!$A$1,0,0,COUNTA(Sheet1!$A:$A))
MyRange will always refer to the filled cells from A1 downwards, and you can refer directly to it in VB, by
Range("MyRange").Select
See other threads in this forum, and John Walkenbach's site (and many others) for dynamic named ranges (that is what MyRange is in this example).
Good luck!
Cheers,
Joerd
Thanks, I was somewhat on track with ab123456's solution but I couldn't figure out the specific syntax of the Rows("1:" & endrow).
I just recently started working with named ranges. The dynamic named range is new to me, looks like a powerful tool, thanks joerd.
