I have been assigned to conduct a feasibility study on implementing cathodic protection on 140 shell & tube type heat exchangers at our site. Exchangers with cooling water on tube side are particularly susceptible to leakages due to poor cooling water chemistry management, CS metallurgy and ineffectiveness of corrosion inhibitors. In consideration of the fact that cooling water chemistry continues to be poor and corrosion inhibitors being not effective enough to improve the situation, please share can we implement cathodic protection system on our exchangers and if so which are the best companies to contact in this regard.
I would also appreciate if you can highlight any limitations of implementing CP system for tubes protection in heat exchangers.
Thanks & Regards,
Thanks & Regards,
