Christopher C
Happy Sunday everyone,
Kind of a 3 part question here...
I am engineering an 11ft retaining wall for a hillside swimming pool. The geotech report predicts limestone about 3 ft below grade. The sub-contractor has requested getting rid of the heel and the toe of this wall, and keying it 2-3 ft into the limestone. At first glance I don't see a problem with designing it this way as long as the rock can be exposed and confirmed. Do any of you have any experience with this sort of detail?... Do you recommend it?... How do I make sure this wall doesn't rotate out of it's key?... Is there anything I should watch out for?
Part 2:
The sub-contractor also told me he was planning on using gunite to fill these forms. This one does not seem like a good idea to me. I understand gunite is used for the shell forming all the time, but I just don't see how they are going to spray gunite inside a form and ensure complete coverage and a consistent density for a 12in+ thick wall. Is this possible with gunite?
Part 3:
The sub-contractor has also requested using sand bags instead of select fill. My thoughts on this are that the bag material should be expected to deteriorate, and thus all the voids between the bags should be filled with fill anyway, and each layer of bags + fill should be compacted. I feel like this would be more work than just laying down fill. Any thoughts?
I believe in being receptive to input from sub-contractors, and I also believe in saying no. I just like to make sure that my "no" comes from a place of reason, and not fear of the unfamiliar. Thank you in advance for your input.
Part 2:
Part 3:
