JoeBaseplate
- May 31, 2011
- 204
Please see the attached sketch. This is a proposed frame for a single story structure, the exterior walls are masonry and there are no interior walls for use as shear walls, thus the need for frames. Wind is the governing lateral load (seismic site class B, Chicagoland). I was going to use type-2 moment frames ( I believe now they are referred to as Flexible Moment Connections) but it appears that more and more designers are turning their backs on the idea. So, I decided to do the cantilevered frame shown. I don’t want to fix the beams because I want to keep the beam-column connections as simple.
My question is that are their still some seismic design criteria I must satisfy even though it doesn’t govern? I am trying to keep the lateral deflection within 2h/600.
