Nov 26, 2012 Replies: 7 Do a cantilever retaining wall need to be below the frost depth at the toe? Click to expand...
Nov 26, 2012 #2 JAE Structural Joined Jun 27, 2000 Messages 15,721 Location US We usually place the bottom of the cantilever retaining wall footing below frost.
Nov 26, 2012 #3 dik Structural Joined Apr 13, 2001 Messages 26,129 Location CA Same here... and we sometimes use insulation to minimise the excavation at the toe... Typical frost penetration in these environs is 6'... Dik
Nov 26, 2012 Thread starter #4 maneesha0702 Civil/Environmental Joined Jun 24, 2000 Messages 45 Location US How much of insulation is needed to decrease 3'-6" frost depth to 2'-0" i.e 1' of cover over toe and 12" thick slab.
Nov 26, 2012 #5 dik Structural Joined Apr 13, 2001 Messages 26,129 Location CA A couple of inches and it should extend a couple of feet beyond the toe... Check with Dow-Corning... they have some info on the use of this. Dik
Nov 27, 2012 Thread starter #6 maneesha0702 Civil/Environmental Joined Jun 24, 2000 Messages 45 Location US Thanks to JAE, dik for your help.
Nov 27, 2012 #7 bridgebuster Active member Joined Jun 27, 1999 Messages 3,970 Location US I've found these to be useful http://www.huduser.org/Publications/PDF/FPSFguide.pdf http://www.toolbase.org/Design-Cons...sign-Guide-Frost-Protected-Shallow-Foundation
Nov 27, 2012 #8 SteelPE Structural Joined Mar 9, 2006 Messages 2,776 Location US I would also check out ASCE-32 which I thinks covers frost protection of shallow foundations.
