Cantilever Plate bending with UDL
SALTRAM4567777
AE
I have a cantilever plate rigidly clamped on one side and free on the other sides, with the plate being very long in the direction perpendicular to the cantilever span. For a point load applied near the free edge, I usually determine the required plate thickness considering load spread at 45 degrees. My question is, for a uniformly distributed load (UDL) along the length of the plate, how should the required thickness be calculated? Do we still apply the 45-degree load spread assumption, or is there a different approach for UDL in this case? Any guidance or references would be helpful.
If the load is uniform in the direction parallel to the fixed edge, you'd typically design that on a unit length basis.
I am trying but I am not able to attach a sketch. Some issue on my side. It's a UDL Line load acting perpendicular .
Treat the plate as a simple cantilever beam. You have a long line load so it is just a simple cantilever calculation with a point load of a unit length x UDL. for a beam that is a unit length wide.
Thanks @BAretired for posting the sketch.
I understand simplifying it to a unit-width cantilever beam with UDL. My only doubt is about the effective width. For a point load on a plate, we often assume 45-degree load spread to calculate bending resistance. In the case of a continuous line load along the length, do we still consider same effective 45 degree effective width, or is treating it as a unit-width beam sufficient for plate thickness design?
I understand simplifying it to a unit-width cantilever beam with UDL. My only doubt is about the effective width. For a point load on a plate, we often assume 45-degree load spread to calculate bending resistance. In the case of a continuous line load along the length, do we still consider same effective width or beyond unit width, or is treating it as a unit-width beam sufficient for plate thickness design?
I can't understand how it can be anything other than having a unit length to resist a uniformly distributed concentrated load at the end of the cantilever. Please enlighten me. I'm new at this stuff. I only started doing structural engineering 48 years ago.
If this case was as simple as you suggest, it would be covered in Roark’s — but it’s not. The closest case is a plate clamped on one edge with the others simply supported. Using a 45-degree effective width from that logic gives a plate thickness far higher than FEA results, making it overly conservative. My question is purely how to determine realistic effective width, so we avoid unnecessary overdesign — not to oversimplify a complex plate bending problem. Years of experience don’t always translate to understanding.
Is one side fixed, two simply supported and the loaded edge free? That's why a diagram would be helpful. BAretired's diagram appears to suggest that the boundary conditions at the two ends of the plate would have little consequence on the effect of the bending of a plate due to a UDL at the free edge. The reason your model is not covered in Roark's is because it is a simple cantilever, solved in simple 2D analysis. Any FEA analysis that would have different results would be suspicious to me.
Beams with relatively great width generate stress in the long direction due to Poisson's effect. Poisson's stiffening effect also influences simple beam theory, where E can be substituted for E / (1 - v^2). Suggest looking at Roark, section 8.11 (7th Edition).
Does that alter the results in the OP's original question?
The information was brought to the attention of the OP, so it may be used if necessary, depending on what criteria needs to be met.
If 45 degrees is appropriate for a single point load at the tip it will be conservative for a series of loads in a line perpendicular to the clamped edge. For simplicity's sake consider a point load at the edge, and one halfway back. System is linear so you can use superposition.
The sketch below is the case where a concentrated load P is applied at the free edge, causing a deflection 'd' at the point of application. Using Yield Line theory, the value of m, which is the plate moment per unit length turns out to be P/8.
For the case of a UDL running perpendicular to the long edges, a similar calculation could be performed along the lines suggested by Greg Locock.
The customary rule of the 45 deg is based on a simple fact: the maximum longitudinal stress at the clamped edge is close to (but lower than) 3P/t2, that is the stress calculated with the 45 deg rule. This can be checked with the calculation sheet available here.
The suggestion of GregLocock would lead to the following results, under the following two assumptions:
- if the 45 deg are taken from the position of each of the elementary loads summing up to the load P, then the stress at the clamped edge is the same as for a load P placed at the tip
- if the 45 deg remain the same as for a load at the tip (in other words, the useful width of plate is 2a), then the maximum stress is halved
Now we engineers would conclude that a reasonable assumption would be at mid way between these two cases, as the first assumption is clearly conservative, and the second one isn't: this gives 75% the stress caused by the load P placed at the tip. By playing a bit with the calc sheet above, I found that 60% (instead of 75%) would be closer to actual stress values (but aren't we splitting hairs at this point?)
I find it remarkable you raise the issue of Poisson's ratio for the UDL but crickets regarding the 45 degree shear lag angle for a concentrated load. fby and fbxy will not govern the design.
I find it remarkable so many people in this thread have spent the significant time discussing a 45degree shear lag when we have a UDL line load. I've been very confused by most of this.
