Cantilever Plate bending with UDL
SALTRAM4567777
AE
I have a cantilever plate rigidly clamped on one side and free on the other sides, with the plate being very long in the direction perpendicular to the cantilever span. For a point load applied near the free edge, I usually determine the required plate thickness considering load spread at 45 degrees. My question is, for a uniformly distributed load (UDL) along the length of the plate, how should the required thickness be calculated? Do we still apply the 45-degree load spread assumption, or is there a different approach for UDL in this case? Any guidance or references would be helpful.
If the load is uniform in the direction parallel to the fixed edge, you'd typically design that on a unit length basis.
I am trying but I am not able to attach a sketch. Some issue on my side. It's a UDL Line load acting perpendicular .
