jtseng123
- Jun 6, 2012
- 530
Dear all,
Anyone who has purchased pressure vessel outside of BC Canada and shipped to jobsite in Canada, would you please advise the following :
1. Does the purchase order package (which contains specifications, standards, vessel data sheets or drawings) require PE registered in BC Canada to review and stamp ?
2. For vendor fabrication dwgs and calculations, noting that each document will be back and forth for review several times, does every revision for review need PE registered in Canada to review and stamp ? or just stamp on the final As-Built document is sufficient ? I was told every revision for review needs PE stamp but the final as-built does not require PE stamp, based on EGBC “Guide to the Standard for the Authentication of Documents” Section 3.4.4 and 3.4.5, 3.2.14, 3.2.15 and 3.2.15.9. I am not quite sure if the interpretation to EGBC is correct.
