Can you replace a sketch in a feature?
trulyshy
I could have sworn I have seen this done..
for example:
you have a sketch of a circle which has been extruded, and a different sketch which is a square. I could have sworn someone showed me how to "replace" the circle sketch with the square sketch.... and the extrude is now a cube instead of a rod...
Does anyone know what I am talking about? Or am I remembering things that have never happened??
Christine
This can be achieved through configurations.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of Eng-Tips Forums?
Madmango,
Do you mean have one configuration with one feature and a second configuration with another feature?
I know I can do this, but while at training I could have sworn I watched the guy have two sketches under one feature and he kind of toggled betweent he two...
Christine
Can you explain more what you are actually trying to accomplish?
Are the sketches in the same part or different parts?
Once a feature is created you can edit any part of the sketch or if necessary delete it entirely and replace it with geometry from another sketch.
[cheers]
I have a part which will have two configurations of a cut.
The cuts are completely different, so I can not alter the sketch from one configuration to the next.
I was going to have two cuts and suppress the one feature or the other in the different configurations. Than I remembered (or so I think I remember) seeing the one guy at training actually have two sketches for on feature and toggled between them somehow. I thought this would be a good way to get my two configurations instead of suppressing the features.
So, now I am on the quest to find out if you can do this or not. You don't need different configurations, but I was planning on using it that way...
He either toggled between two sketched, or replaced on for the other... it seemed easy enough to remember at the time, so I didn't bother writting anything down...
You could have multiple shapes drawn in a sketch and toggle each shape from construction to solid geometry. Perhaps that is what you were being shown. I can't think of a valid reason to create a feature that way though. A config with different features would be a much simpler toggle.
[cheers]
yes, I've seen the multiple shapes in one sketch and toggle them, that wasn't it.
Boy, this is starting to get scary. I honestly could have sworn..
It was almost as if he had done a copy past of the sketch in the feature tree. At first I thought he RMB and did a replace, but I looked there is no replace...
I will have to call the guy and ask him, this is staring to bug me now.....
Christine
If you were using a Swept Cut (or any cut where a sketch profile has to be selected) you could then edit the feature and switch sketches ... but that would involve having separate sketches.
[cheers]
I don't think there is a replace sketch only a replace component... What I think you saw was a configuration switch... where you can suppress one feature and then the other feature per the config used.
Scott Baugh, CSWP [pc2]
faq731-376
Yes, he had seperate sketches...
How do you switch sketches in this case?
Maybe this is what I remember..
C
Make each sketch into a feature.
Make 2 configs
In one config suppress the circle feature
activate the other config and suppress the square.
Now if you toggle between the 2 configs one feature will be a circle while the other will be a square.
faq731-376
No, dang, that wasn't it... I know it wasn't two configurations. But, this is how I will do it...
But, I will still call the guy. I will update and post it if it is possible, or let you guys know that I'm slowly but surely fading....
Christine
trulyshy,
Could it possibly have been different sketch contours? Draw 2 closed profiles in the same sketch and select which portion(s) of the sketch you want to use for the extrude feature.
trulyshy ... you can only switch sketches in certain types of cuts. Sweeps, Lofts, etc, where a profile and a path are required. I don't know of a way to switch sketches for a regular cut-extrude.
[cheers]
Ok,
I was not able to reach Mike. I left him an email, so I hope he replies soon. Maybe it was in a sweep or loft where he showed it to us... and that is what I am remembering...
dgowans ... Yes, that would do it.
I still think a config is the better way though. It is much easier to see when trying to troubleshoot the part weeks, months, years from now.
[cheers]
I will have to do it with configurations. Even if I can switch out the sketches, how do I control them in the different config's.... so, two different features is probably the way to go.
C
Ahhh but I do know a good reason why you would want to do it this way....
If I have a extrude early on in my feature tree, and I suppress it in one configuration, I might be suppressing children too which I might not want suppressed...
If I can just use a different sketch, I don't suppress everything...
It is Constuction Geometry in a sketch. put in two sketches. Make a square and a circle. Now toggle the circle to constuction geometry, it will use the square. Go back in and use construction geometry to turn them back.
Is this it?
1 feature. using construction geometry to go from square to circle.
RFUS
