I have continued to learn more about "P" numbers and I ran across this explanation:
In a nut shell:
******"P numbers are groupings of base metals with similar welding characteristics that have been approved for pressure boundaries when constructing pressure vessels or piping systems. Group numbers are sub-groupings within a P number that further subdivides the P number. Group numbers, as mentioned by John Boy, becomes an essential variable when notch toughness is a code requirement.
S numbers are similar to P numbers, but materials listed are not approved for pressure boundaries. They can be used in situations where there is no pressure differentials involved. I like to think of those materials as being appropriate for structural application, not pressure containing applications. Some construction codes do permit specific S numbered materials to be used in piping systems, so check your construction code.
Materials listed by ASME in P numbered and S numbered groupings are listed in AWS B2.1 under corresponding M numbered groups. Similar groupings of base metals can be found in NAVSEA welding standards as S numbers (not to be confused with ASME S numbers)."*****
If this is correct then I need to say that the cast products are not for "pressure" vessels although the C1Q is part of the below water portion of a ship's hull.
The A1Q is for the rudder.
