I am trying to simulate the performance of a compressed air energy storage system.
I have modeled the compressor using the following equation
The compressed air pressure in the tank is changing according to the following equation
The outlet pressure of the compressor is 15 bar and the maximum air pressure limit of the compressed air tank 30 bar with a constant volume. By running the simulation and supplying power to the compressor, more compressed air mass flow rate is generated and fed to the air tank and the pressure increases in the tank reaching 25 bar in my case. Can the air pressure in the tank exceeds the maximum outlet pressure of the compressor ? Is there like a non-return valve or something for that ?
