Can someone tell me what this valve is?
Avk19
Agricultural
Sep 25, 2016
1
I was wondering if anyone could tell me what this valve is and what its used for? As far as I can tell it's some kind of solenoid operated valve, but that's about all I can figure with my limited knowledge. It looks pretty specialized so its got me curious. Anything you guys could tell me would be great!
 http://files.engineering.com/getfile.aspx?folder=336d4d91-478e-4e5e-8e8e-27ed32eda9c9&file=IMG_20160925_193023550.jpg
Eaton/Vickers can tell you, by means of cut sheets for the three valves stacked in the photo, or corresponding catalogs.
At least do a search for each of the model numbers on the tags; we can't see them in your image.
Come back if you still have questions _after_ doing a little of the work for yourself.
Mike Halloran
Pembroke Pines, FL, USA
It's a pilot operated directional control valve.
CETOP 7 or NG size 16.
Pressure reducer and relieving valve in the middle and a linear transducer on the main spool to measure the position.
