Sep 17, 2024 #1 inau Civil/Environmental Joined Sep 17, 2024 Messages 1 Location KW Hello, I need to calculate vertical(Pv) and horizontal(Ph) water pressure in the below situation. There is an object in the water, so please check if my calculations are correct.
Sep 17, 2024 #2 BEMPE16524 Mechanical Joined Feb 17, 2008 Messages 370 Location SG Pressure increases linearly with depth P=ρ⋅g⋅h g = 9.81m/s^2 If you are calculating absolute pressure (as opposed to gauge pressure), you would also need to add atmospheric pressure (approximately 101.3 kPa) to the result. R.Efendy Upvote 0 Downvote
Sep 17, 2024 #3 LittleInch Petroleum Joined Mar 27, 2013 Messages 23,025 Location GB This is very basic fluid here.... Pressure in a fluid ay any point acts equally in all directions at the same time. Your something makes no difference. Only that 1.5m (vertical height) is relevant. Remember - More details = better answers Also: If you get a response it's polite to respond to it. Upvote 0 Downvote
