Greg80
- May 16, 2008
- 25
Can S/S B8 studs and S/S SA194 Nuts be used on Carbon steel A105 Flanges ?
I have an application that the external environment is corrosive and from experience the Studs and nuts are always corroded after few months. However the flanges don't corrode because they are painted with special painting resisting to the environment.
So I would like to use S/S studs and nuts on C/S flanges. Anyone has any idea if it can cause any problem ?
Thank you
