Can I add a 2nd vertex to a leader?
Trent5791
NX 8.5 Does anyone know if I can add a 2nd, 3rd etc vertex to a hole call out leader or a note leader?
a note: yes
a hole callout: no
On the note menu expand List and then click on New
If you use a note, simply double click the leader. In the note dialog under leader you will see a button that says 'specify jog position' click that and then click where you want the leader to 'break'. You can add as many jog positions as you would like.
