Hello:
According to ASTM A 609, reference blocks shall be made from cast steels that give an acoustic response similar to the castings being examined.
I have a supplier (overseas)that cannot pour heavy test-blocks for a 40"- facewidth gear; however, it has a forged bar which can easily fulfill the requirements (including chemical analysis).
Not being a U.T expert I ask:
1. Is it acceptable to use the forged bar as opposed to a heavy cast test-block ?
2. Assuming that a forged bar has a traditional tendency of being of a better quality than a casting (same alloy and same heat treat), would I be violating the ASTM STD by drilling the flat bottom holes on a forging ?
3. Would the calibration results obtained on a forged bar be deceiving due to its different manufacturing form ?
Thank you .
Thank you .
