jefrojo
Aerospace
- Jan 26, 2005
- 4
Hi all,
When calculating the positional tolerance of a pattern of holes that are on a bolt circle and are located by a shaft going into a hole, do I get any bonus/minus because of the value of the adjustment between the hole and the shaft at MMC?
(See attached)
With the fixed Fastener equation, I would get a positional tolerance of dia0.1 at MMC for the clearance holes (In reference to my DIA50g6)
Because I have a clearance of .009 at MMC between the hole and shaft, do I need to remove it from the positional tolerance?
(See attached)
