Stone Jordan
Petroleum
Guys I can't seem to find a correct answer after digging and searching for t-min on SA-178/A economizer tubes. I have the calculation from 2023 ASME SEC I (PG-27.2.1).
This is what I have so far and I'm stuck.
(P) Pressure=850PSIG
(D) Diameter=2.00" OD
(S) Stress=13,400 (According to ASME SEC II Part D Table 1A
(E) Efficiency= ??
(W) Weld joint reduction factor=??
I'm stuck on figuring out exactly what E and W would be? When I scroll down to see it says (W) would be in PG-26 of ASME SEC 1 when I look at the table in the notes it says PG-26 nor Table PG-26 is not required for carbon steels so would I just take it out of the equation?
When looking for E on PG 27.4.1 it starts talking about cylinders and heads, nothing to do with boiler tubes so I'm completely lost on this one. Any help is greatly appreciated.
(E) Efficiency= ??
