Bystronic & Trumpf CO2 laser cutting machine retrofit
renzhi
Industrial
Jul 28, 2020
4
What are the advantages of fiber laser?
1, with lower cost of use, at least 30% of electro-optical conversion efficiency;
2, with longer maintenance-free time, laser source warranty 2 years;
3, with a higher energy density, cutting speed of less than 8mm is obvious;
What are the benefits of CO2 Laser cutting retrofit upgrades?
1, you can use the existing CNC system, whether you are trumpf and bystronic barnd equipment, you can maintain the existing operating methods unchanged;
2, can use fiber laser, no laser gas, reduce operating costs;
3, 100% reuse of equipment, 30% increase in efficiency, operating costs reduced by 50%;
Who will sign off on the system's safety? I foresee lawsuits. This could be bad for the industry.
Chris Krug Maximum Up-time, Minimum BS
