Dear all,
I thanks all for your time and efforts.
I found my mistake, i compared with Pcr not with Pey(correct).
Excuse me, there is another example when i tried to compare the SAP out put value to Pey in the moment frame with fixed base(attached-s2k file), i found difference in the results as the following:
for W12x72 cols(L=3m)and beam(L=6m)section
a=136.13 cm2, r3=13.51 cm, r2= 7.72 cm
1-for manual calculation:
GA=1, GB= Lb/Lc = 6/3 = 2 because the E and I are the same
K from alignment chart-sides way uninhibited= 1.45
Fey=?²*E/(KL/r2)²=?²*2038.9/(1.45*300/7.72)²=6.34 t/cm2
choosen r2 because the first mode from sap buckling about axe2-2
2-for SAP file
Pey from the first mode (buckling about axe 2-2) = 308
Fey= 308/136.13=2.26 t/cm2
please,Can anyone explain why and if any one has a source for solved example in the buckling analysis in sap?
your co-operation will be high appreciate
thanks alot
