juandavidguzman
I’m using SAP2000 v26 to design steel structures based on AISC 360-10, and I'm configuring a nonlinear analysis for the structure. I use the Direct Analysis Method and apply a process where each load case starts with the structure deformed under dead load (state D). Additionally, I adopt K=1 for all elements and have set Tau-B Variable for stiffness reductions.
Is it still necessary to apply notional loads if I’m already considering a nonlinear analysis with deformations? If yes, how should I configure these notional loads in SAP2000?
