B
bac478
Guest
I have a question of preference that relates to axial patterns. For circular hole patterns, I like to use an axial pattern feature so I get the built in bolt circle in the drawing. However, I run into a lot of "issues" when the spacing of the circular pattern is irregular. This requires the use of a table type pattern which, in my opinion, is a little clunky. They only allow dimensioning from a single reference so angles over 90 deg. or worse, over 180 deg. are encountered. Dimensions like this are terrible to show on a drawing and make everything look messy. I would much prefer to dimension everything using a simple extrude feature, that way I have tons of flexibility. However, I don't get the nice bolt circle in the drawing and I end up having to create a separate sketch just to show the bolt circle and then align all the axes of the holes I created with the extrude.
My question is what method do most folks use to deal with this problem and create irregular circular hole patterns? I am on WF4 currently.
