Bolt Bearing in a Shear Connection 5
dik
CA
The Canadian steel code S16 allows for bearing equal to:
3 x ϕbr x n x t x db x Fu
where ϕbr is 0.8
n is number of fasteners
t is the thickness
db is the bolt dia
Fu is the UTS
I couldn't find anywhere that clarifies that this is the bearing material and not the bolt, and why would the value be so relatively high? I assume the AISC has something similar.
Dik
And they say they can't teach old dogs new tricks. They've never met BA or Dik before obviously.
Retired13:
with <Win><Shift><S> you can eliminate a couple of steps... by immediately capturing the 'snapshot' you want. Forgot to add that you can capture parts of *.pdf documents that you normally couldn't access with pdf 'snapshot'.
Dik
I don't know about Bart... but, I'm not that old... still active in engineering after 50 years.
Dik
Dik,
Thanks for the tip. But I still have to drop it to another program to be able to upload to the forum. Can you directly paste to E-T?
Longer than a bulk of us members have been alive.
Yes by doing exactly what I described to BA above
Jayrod12 said:
I do use win shift S.
Then click the image button and click within the area that says drop file here. then I ctrl-v. all done.
If you've been engineering for 50 years, dik, some would say you're getting a bit long in the tooth.
BA
retired13:
See jayrod's post above...
Dik
This is the step I failed. After copy, I got an editing window without the ability to paste to E-T, but another program. I guess I screwed on the "image button", which button is that?
Ah ha. Thanks. Another old dog joining the rank now :)
