Dear All
As per ASME SEC I What shall be Minimum nozzle Thickness as per PG-43
ple see below example
Nozzle DN 50( 2 in)
PG-43
The minimum thickness of a nozzle neck shall not be
less than the thickness required for the applicable loadings.
As per my internal Pressure this thickness is-2.18mm
PG43.1-The minimum required thickness of a seamless
shell or head to which it is attached
this thickness coming-13.46mm
PG 43.2 The minimum wall thickness of standard-wall
pipe listed in Table 2 of ASME B36.10M
this minimum thickness As per SCH STD is 3.42mm(including mill tolerance)
as my interpretation i can select sch 40 in design
or i no need to add Corrosion allowance in Sch 40
