We analyze a lot of existing lattice steel structures (electrical transmission industry) with odd bolt patterns in angle connections.
Assuming minimum end, edge, and bolt-bolt distances are met, the basic block strength is At*Fy + 0.6*Av*Fu.
See the attached drawing. In the top and middle connections, the obvious failure paths would be the dashed lines.
Top connection: A quick analysis would just use the "s" lengths in the shear path length calculation, a more precise calculation would use the slightly longer "ss" lengths.
Mid connection: Shear path is straight, ignoring the first hole in the second gage line. Tension path length would be f + g2 + s2/4g2 - 1.5 holes, similar to a basic net-section calculation.
The bottom connection is the question. At what point does the failure path transition from a straight path (1) to one that passes through the second hole (2)? The s2/4g solution for the tension path has been around for over a hundred years, but I can't find anything on a "reverse slope" scenario, where the slope is in shear+compression. The conservative answer is to just assume the strength along both lines is the same (0.6*Fu) and use the shortest path. The detail was drawn specifically such that Path 2 is slightly shorter (accounting for the extra bolt hole) than path 1. But are we being too conservative? Does it have a higher strength due to the "reverse slope" section?
I'm working on a spreadsheet where we can rapidly input the bolt pattern information and it'll check all the possible failure paths to get the controlling failure block. As of now we're using the basic shear strength value for the sloped line in compression, (0.6*Fu),and not taking any credit for the compression component.
