They are using packing and the issue is that they have a configuration of the vessel they change it from inside the vessel. So, I would have to install the cartridge in the shaft but in the inside side and the cartridge will work in reserse, I mean the product would come from the locking ring side.
Doing like this we avoid to use a split cartridge. shaft 120mm
Do you think it will work well?
The idea would be to install a double cartridge no pressurized and to introduce beer in the chamber through the quench connections, as other product can not be introduced.
See the drawing attached.
What do you think? another alternative?
