ChiEngr
- Oct 19, 2021
- 77
Hi everybody,
I am looking for some input on the following scenario. I have a 1-story building with Seismic Design Category C. The structure is comprised of CMU shear walls around the perimeter, and the roof framing is steel roof deck spanning to cold-formed steel premanufactured trusses. The lateral load is transferred from the diaphragm to the load-bearing shear walls below through in-plane blocking or transfer truss running parallel over the walls. I have increased this collector force by the overstrength factor per code, and I am providing steel plates between each truss bearing with a couple of Hilti KBTZ2 anchors to transfer the shear load to the wall from the in-plane transfer truss above. I am not sure how the manufacturer will connect the truss to the plate just yet, but I assume it will be a welded connection.
My question is with regards to the anchorage of this plate to the wall itself. I was debating on using headed bolts, but ASTM A307 A bolts do not have a specified yield stress that I can use to calculate the shear capacity of the bolts. Has anybody performed a similar top of CMU wall type connection, and if so, which bolts did you use?
Thanks for your time and help!
