Hi everybody,
I have a problem, and a possible solution that I would like to hear your comments on as far as its validity.
Problem:
An existing structural steel beam(say beam 1) has been loaded by the addition of some new structural steel in order to support the weight of some substantial machinery. The new loading on beam 1 is fairly complex in nature and of course the steel drawings have dissapeared. So my problem becomes how can I determine the loading on this beam and the applicable stresses present so I may determine if even more weight (thats right my client wants more) can safely be added to beam 1. I do know how I can step through the process with FBD's and calculate the loads, deflections, stresses ect.. in this manner, however the environment is extremely hostile and again the loading is very complex. So an Idea I am considering and would appreciate your comments on is as follows:
Solution?:
Using a laser alignment tool used for aligning couplings, shafts and also for determining straightness of plates I would like to measure the existing deflection of this beam. I can easily start at a point of zero deflection, say the beams connection to its column and procede outwards toward the beams center. Now I realize this method is going to require some substantial assumptions and this is where my concerns lie. But what I would like to do is assume that at the very least this beam was made to AISC published values regarding mill tolerances of Camber. Then I would assume that the beam was placed into the structure "crown up" and all measured deflections would be added (down being positive) to the maximum allowable beam camber listed by AISC. So the measured deflection + The maximum allowable beam camber would be the value used in my calculations regarding beam streses. After obtaining this information I'm confident in my ability to perform the calculations remaining. I hope everybody understands what I'm stabbing at here, and that you might be able to offer some insight. I sure would appreciate any comments regarding this problem, and would be happy to keep you posted if your intersted on how the job turns out.
Many thanks,
Caleb J. Bell
Problem:
Solution?:
Many thanks,
Caleb J. Bell
