I am currently working on a project where I have to make a foot walk on a crane OSHA compliant, to meet the 48" rule from low obstruction the deck has to be lowered below the girder (W24x100) and outrigger (W16x26) by about 4-5 inches. The beams are 47 inches apart centerline to centerline and the distance between runway rails is 47' 6". Initially made drop down foot walk supports every 5' utilizing C channels see attachment for picture. During the calculations of the outrigger with the large span and the distributed loads from the live load and dead loads the outrigger fails in LTB. I am trying to figure out a way to have the foot walk deck supports act as bracing between the 2, I have looked at AISC and from what I can understand they would act as tension flange torsion bracing. So I was thinking of using AISC App 6.3-2 to size the floor channel for the strength and stiffness along with placing full length web stiffeners at each of the foot walk support locations in both the outrigger and girder thereby reducing the unbraced length of the outrigger.
My questions are:
1. Am I using everything correctly?
2. What can I do to brace these beams together enough to reduce the unbraced length?
My questions are:
