jochav5280
Good day,
I'm designing a heavily loaded (2000 kip) steel wide-flanged, concentrically braced frame connection where the brace will be mitered and frame directly into the joint, with the flanges CJP welded to the column and beam flange. My question is what calculation should be carried out to check the base metal capacity of both the column and beam flange for both the horizontal and vertical component of the flange force? My intuition is that the flange base metal capacity should be a function of it's thickness, however, there is no clear shear plane through the thickness of the flanges, so I'm unsure as to how to check the base metal.
A colleague of mine insists that the thickness of the beam or column flange does not come into play at all with regard to the strength of the base metal, however, this does not make intuitive sense to me. To illustrate my point, it doesn't make sense that one could weld a 5-inch thick brace flange to a 1/4" beam flange and expect the beam flange to not tear away or fail.
Any light you all could shed on this would be greatly appreciated. This is a very highly loaded connection, one which I cannot find any design example for, but need to ensure it has adequate capacity.
Best regards,
jochav5280
Best regards,
jochav5280
