Ball Bearings running in Aviation Fuels 1
RedCoat999
Does anyone have any experience with derating ball bearing life for running with aircraft Jet A type fuels as the only source of lubrication (flooded)?
No. Never tried that.
A general reflection is that an all-steel bearing probably will not work very well. There is no lubricating film and the metal/metal interface is known to be vulnerable and cannot support much load.
I would look into hybrid bearings with ceramic balls. They do avoid the metal/metal interface and should have a better chance of survival. A hybrid bearing can run dry for quite a time, which an all-steel bearing cannot.
Gunnar Englund
If the loads are light, you may look into plastic bearings with either stainless or glass balls. If you had not mentioned "aircraft", I would have recommende our Cobra Solid Lubricant, which will run in a stream of solvents!
Russell Giuliano
Unique Technologies Associates - Cobra Solid Lubricant
Can you advise any speeds and loads? This way we can work out how the surfaces will be loaded and then select material options.
Cheers
Neville
Speed = 5000 rpm
Radial Load = 175 lb
Required bearing bore size = 12mm
Fluid Viscosity = <1 cs
(by the way, if user AHRBearing is anything to do with I couldn't get to any pages on the website other than the main page)
