Dear all,
Any idea what is the possible cause of the failure of this angular contact ball bearing? Attached is the photograph of the ball bearing 14 out of 15 balls have the similar pattern on the ball with the initiation site at the center and propagate radially like fatigue striation. The outer and inner raceway show microcrack and spalling but not as severe as the ball. They are 1 inch ball bearings.
Note: Why I could not upload the file...why doing this ...this statement came out.
Runtime Error
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
<!-- Web.Config Configuration File -->
<configuration>
<system.web>
<customErrors mode="Off"/>
</system.web>
</configuration>
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.
Anybody can help me...
Happy New Year...
Runtime Error
<configuration>
<system.web>
</system.web>
</configuration>
Happy New Year...
