Under ideal operation conditions you should be operating with a slight vacuum between your turbine exhaust and condenser tubes. You can measure this with a pressure gage at at point between the two. Back pressure is your enemy. This is caused by too much steam, lack of cooling supply to condensers, large air leaks into the condenser, lack of air extraction.
Dugal
