Hi All,
We have these large process gas compressors on the ongoing construction of our Ethylene Cracker Plant. One of our current issue is about the lube oil pump operation. The main lube oil pump is a steam turbine driven and an auxiliary pump that is motor driven. However, one question arise during our Hazop, that the event of maintenance of the steam turbine driven pump, the motor driven pump will be online. Then after maintenance, the steam turbine driven pump will be the standby pump. However, to have the flexibility of operation, we want these steam turbine driven pump to be on auto-start-up which would modify the lube oil accumulator sizing. The normal start-up of a motor is 4 seconds while on the turbine that we bought is 17 seconds and will have an impact on the accumulator sizing. What is your current design on your plant?
