I am designing a small plastic enclosure (.65" dia. x 3" long) that houses a metal transducer. Both ends of the shell are sealed with o-rings and there are small amounts of moisture present inside the shell after only a few autoclave cycles. The autoclave is 135deg C for 10 minutes. The pressure is 38psi and the material is Ultem HU1000 at a .100" wall thickness.
Is it possible that the steam is permeating through the Ultem? I have made similar enclosures from Radel without this problem. Any help is appreciated.
