ASME Sec. IX WPS questions
glazetm
Industrial
I have some simple WPS questions for you guys; Due to my lack of experience in termonolgy i am not sure what these mean. I will list them in a table below.
[b]Filler Metal (QW-404)
-spec no. (SFA)_________________?
Gas(QW-408)
-Flow Rate(CFH)__________________?
Techinique (QW-410)
-Oscillation____________________?
-Balance_________________________?
-Travel Speed Range (IPM)_______________________?
[/b]
Can anyone go into detail on what there terms mean to help me understand. Also do any of you have any documents or books on writing and understanding WPS.
Thanks for all your help to a green QA/QC.
Thanks,
Tommy
TOMMY3021;
Yes, first get yourself a copy of ASME Section IX. This is required for what you need to do for review, drafting and qualification of welding procedure specifications. Next, search the internet for information on various welding processes so you can understand the terminology associated with specific processes. Third, find a Welding class either though the National Board or through ASME Boiler and Pressure Vessel code to attend.
SFA Specifications are found in ASME Section II, Part C; e.g. SFA 5.1 covers SMAW coated electrodes, SFA 5.9 covers bare stainless steel electrodes.
Gas flow rates refer to the volume of inert (Argon & Helium) or active gas CO2, Argon-CO2, Argon-O2 mixes)
used in shielding or purging per unit time during gas shelded arc welding. CFH = Cubic Feet per Hour.
Oscillation refers to to the width (across the joint), freqency and dwell time at the joint edges for automated or machine welding. It does not apply for manual welding.
Travel Speed is the speed of welding along the length of the weld - usually measured in inches or centimeters per minute.
Balance - Don't know what you are asking.
Thank you all, I am a welder/pipe fitter by trade with an A.A.S. in Industrial design and new to Q.A/ QC managment. Back when i use to weld we just used different terminolgy when it came the welding. I appricate all yall help! I uses this site regulary and recieve nothing but helpful comments in return.
THANKS!
Thanks,
Tommy
Tommy,
Try the CASTI Guidebook to ASME IX - will help you understand ASME IX,
Cheers,
Kiwi
