Hello:
Please see my application below, but I a requesting recommendations for a very good ASME Pressure Vessel & boiler code guide book. I do not wish to purchase the entire ASME code (over $10k) for a simple single project.
I am working on a short term project designing a machine (which I have experience with) that will fit inside a fabricated pressure vessel that will operate under vacuum (which I have no experience with).
The tank uses "standard" ASME heads and I have specified that the vessel cylinder walls match he material grade and thickness of the heads. Welding is being done at an experienced tank fab shop, with ASME certified welders.
Again, I am looking for recommendations on a good quality ASME pressure vessel and boiler code guide book (that I can use in place of the whole code) that will give me enough information to understand and properly specify ASME related code vessels/welds/etc..
Thank you,
Sean
Thank you,
Sean
