ASME B31.3 - Para. 320.2 - Sustained Loads 1
Fuzzbox 100
GB
Hi all.
Does anyone have any 'worked examples' of the the sustained load calulations in para 320.2 that they might be able to share or 'signpost' me towards?
I'm not talking about a 'Ceasar' print out, rather a typical 'manual' example of how the calcs work?
Many thanks.
Refer to B31.3 APPENDIX S (PIPING SYSTEM STRESS ANALYSIS EXAMPLES), which contains a typical 'manual' example of how a code calc works goes. Para S301.6 (example 1) specifically deals with the sustained load case and refers to para 320. There's also an example 2 in para. S302.
Huub
- You never get what you expect, you only get what you inspect.
