Jul 30, 2024 #1 FPPE Mechanical Joined Mar 4, 2022 Messages 196 Location IT Hi, We have to design and manufacture the following pipeline in accordance to ASME B31.3: Is it possible to obtain a 1/2" 90° elbow (even long or short radius) from a bended tube SCH. 80 in ASME SB-165 N04400 (Monel 400)? Thanks in advance
Jul 30, 2024 #2 LittleInch Petroleum Joined Mar 27, 2013 Messages 23,012 Location GB It's not a pipeline it's a piece of pipe. And yes, just bend it over a mandrel. Or pipe bender. The Iso shows no fitting so the designer thinks it can be bent from a straight piece of pipe on site. Remember - More details = better answers Also: If you get a response it's polite to respond to it. Upvote 0 Downvote
Jul 30, 2024 #3 EdStainless Materials Joined May 20, 2004 Messages 16,366 Location Waukesha WI USA If you bend on site, then you should UT check the thickness of the outside of the bend and measure the external ovality of the bend. There are limits on both of these. = = = = = = = = = = = = = = = = = = = = P.E. Metallurgy, consulting work welcomed Upvote 0 Downvote
Jul 31, 2024 Thread starter #4 FPPE Mechanical Joined Mar 4, 2022 Messages 196 Location IT Thank you for the answers. EdStainless, why did you mention "If you bend on site"? Don't we have to follow this requirement if we perform the bending in our workshop? Upvote 0 Downvote
Aug 7, 2024 #5 david339933 Industrial Joined Jun 15, 2011 Messages 1,204 Location CA Check vs 304.2.1 Upvote 0 Downvote
