I'm designing a steel tank with no floor and a liner to contain water. Since the liner is ground supported any water in the tank does not contribute to overturning resistance.
However if there is a negative internal pressure acting on the roof that would resist overturning. Since there is a gap all around the roof edge there should be some -ve internal pressure but I'm inclined to think that the internal pressure should be taken from AS1170.2 Table 5.1(A, all walls equally permeable, Cpi = -0.3 or 0.0, in which case it would be taken as zero and does not help overturning.
Does that sound right to you?
