API/ASME Joint Efficiencys in 1945.
QAScott
I'm looking for the types (%) of joint efficiencys of welded joints for a pressure vessel built to the API/ASME code in 1945. I have the ASME Sec VIII 1945 but need to know what the joint E may have been used for API/ASME vessels.
Thank You,
QAScott
QAScott
Contact Bruce McWhirter at the Alberta Boiler and Pressure Vessel Safety Association ( Bruce is the head of design survey and a wealth of information. I have contacted him in the pass on similiar issues . ABSA has a library of old Codes and standards
niteattheopera,
Thank you for your help. I was able to find the API-ASME code book and that I was looking for, and I now have all the API-ASME code books. I hope I can help you some time.
Thank You,
Scott
