I am currently working on OH2 type pump that is in compliance with API 610 11th Edition.
Connection sizes are as follows : Suction : 6" /300lb/RF
Discharge : 4" /300lb/RF
Material of construction selected for this application is A351 CF8M.
I have a concern in terms of hydrotest pressure.
Now,with reference to API 610 11th Edn,6.3.5b)MAWP is equivalent to 40barg at 38 degC.In this regard,Hydrotest pressure should be equal to 1.5 times MAWP,that is 60 barg at 38 degC.
But when i referred to ASME B16.5 for flange fittings,in table 2.2.2,maximum working pressure for flange rating of 300 lb at 38 deg C is 49.6 bar
Having outlined that above,my question is
- Is it feasible to perform hydrotest at a pressure ( 60 barg ) in excess of max working pressure (49.6 barg) of flange fittings at the said temperature ?
Thanks for your reply in advance.
