metalman8357
Materials
Hi all,
I have a cylindrical mandrel (0.34" OD) that has a 0.188" flat to flat hex recess broached into one end of the mandrel. A hexagonal bit fits into this 1" broached recess, and the bit has an oversized ring on the end that expands into an undercut once it is inserted far enough into the mandrel. This is to ensure that the bit cannot be pulled out of the mandrel while it is in use. To remove the bit, we have a hook tool that fits into a pilot hole on the mandrel and acts as a cantilever on the back of the bit that allows the snap ring to compress and the bit is ejected. The problem is, we are lengthening the bit and the recess, and once the snap ring is cleared of the undercut by the ejection tool, it is still too hard to remove by hand. I have been asked to redesign the mandrel so that the bit cannot be pulled out during service, but then can be easily removed when needed. At first i thought of a ball detent, but the assembly required is outside the budget for this part. I'm just looking for a clever mechanism that can achieve the same function that I described. Any suggestions would be greatly appreciated.
Thanks,
M
Thanks,
M
