Tmoose
- Apr 12, 2003
- 5,636
A machine shop has reported that some castings we sent for machining are harder than our drawing specifies.
" These parts are harder than the drawing states. We are having an issue machining the parts. The parts measured are measuring 59, & 60 Rockwell C. We anticipated 500 HB, which is 51 to 52 Rockwell C. "
They are suggesting to soften the parts (to HRC 40) for machining, and to then re-harden them.
" Can we make this part softer? Then we would harden it after machining? "
Attached is an image of 2 similar parts we have made before.
For The shorter, simpler part we called for an as cast hardness of 500 HB.
The longer, more complicated part calls for the part to be annealed to 400 HB.
I guess we specified the current parts to be as cast 500 HB.
We have approached the foundry to answer questions about softening and heat treating options.
I foresee problems with distortion and perhaps even cracking of the finish machined parts.
(The castings already are distorted enough to require dimensional compromises).
My question is, can high chrome cast iron be "heat treated" to re-harden to 500 HB after annealing or even tempering to 400?
Some of the curves in the "Abrasion Resistant Cast Iron Handbook" suggest some high chrome irons can end up with vastly different hardnesses even after tempering to the same temperature, depending on retained austenite.
