Anchorage of Positive Moment Reinforcement
IreStruEng
IE
Clause 8.3.1.3 of AS 3600 states that "Not less than one half of the tensile reinforcement required at midspan shall extend past the
face of the support for a length of 12db, plus a cog or an equivalent anchorage;"
For 16mm diameter reinforcement, 12db = 192mm. Adding in cover and the thickness of the supporting wall/column is going to need be >=230mm.
Say two 16mm dia. bars are required at midspan of a simply supported beam for the flexural reinforcement. If both bars are taken 6db (96mm) past the face of the support is that clause deemed satisfied in your opinion?
Not technically by the language of the clause.
Doubling the bars required and halving the embedment conditions doesn't usually work out.
No I don't agree with that. The point is to ensure that some steel is fully developed...doubling the steel and putting in shitty development length on both doesn't meet this requirement
Also, I suspect that the development length required is more than 230mm?
You have 12db PLUS a cog (which I'm interpreting as a 90 degree hook?) - I assume there is an additional straight length of Ldh + the radius on the bend that you need to fit in as well?
Yes a cog is a 90 degree hook so it will be more than 230mm by the time you account for that.
It seems excessive to me that you'd have to have a really wide support for a simply supported beam that isn't doing much work. I don't have a specific scenario that I'm designing for right now but anchoring 16mm diameter bars from a simply supported beam perpendicular to a 200thk wall would require a local thickening of the wall at the bearing location.
