IreStruEng
Clause 8.3.1.3 of AS 3600 states that "Not less than one half of the tensile reinforcement required at midspan shall extend past the
face of the support for a length of 12db, plus a cog or an equivalent anchorage;"
For 16mm diameter reinforcement, 12db = 192mm. Adding in cover and the thickness of the supporting wall/column is going to need be >=230mm.
Say two 16mm dia. bars are required at midspan of a simply supported beam for the flexural reinforcement. If both bars are taken 6db (96mm) past the face of the support is that clause deemed satisfied in your opinion?
