analysis distance in NX3
Sandviken
Automotive
New user to NX3 coming from V.18. Just wondering how to get a distance from point to point. For example I have 2 cylinders and I want to know the distance from center to center. I used to use the point subfunction option in V.18 and just choose center to center. It does not seem to be there in NX3. Any help or tips would be appreciated.
You will need snap point toggled on and you can select your arc center.
Justin Ackley
Design Engineer
jackley@gmail.com
Sandviken,
The first thing you need to do is aquaint yourself with 'Selection Intent' and the associated toolbars. I had the same problem as you and could have saved a few brain cells if someone had made the point up front.
When taking a distance measurement in particular to your question, the snap point is probably set wrong for specifically trying to snap to 'arc center' (the toolbar snap intent is set for endpoint, control point, etc...) so a quick click of your selection intent will fix your problem (turn off control point, end pt, whatever... and click on 'arc center').
Hope this helps...
SS
CAD should pay for itself, shouldn't it?
Thanks for your response.
that helped me out.
AG
Can you now select Axis for distance references, they were always unavailible for selection and it seems parallel axes should be selectable so you wouldn't need to create or snap to points when a Datum already exists?
Michael
mjcole,
...not that I've found, but this has never been an issue with me. Perhaps somebody else can chime in....
SS
With NX 4.0.3.3 you will be able to select a Datum Axis as a valid objects when performing Distance and Angles measurements in Analysis. This is an enhancement over NX 4.0.2.2.
John R. Baker, P.E.
Product "Evangelist"
NX Product Line
UGS Corp
Cypress, CA
a little offtopic:
John, you already mentioned in two threads here 4.0.3.3. When it will be available for download. I only see nx-4.0.1.3 and nx-4.0.2.2 uploaded on the ftp server as a maintenance-release. Or am I missing something?
sorry for the off.
_____________________________________
Complex problems have simple, easy-to-understand, wrong answers.
_________________
PI Penkov
CAM Programmer
Non-standard Equipment Designer
NX 4.0.3.3 will be available for download by customers in early November. Internally, we got our first verification copy of this maintenace release last week and if all goes well, it will be certified and made available in the same manner as past mainteance releases, including the issueing of a software field bulletin when it's official.
John R. Baker, P.E.
NX Product Line
UGS Corp
Cypress, CA
OK thanks to Mr. Baker and excuse me Sandviken for the offtopic in your thread.
_________________
PI Penkov
CAM Programmer
