AJgeo,
Under your sheet run you will need to set your bottom dimension. If you are using V8 look under Margins and Spacing. However if you are using Microstation J or Geopak 2001 Under Cross Section Sheets go to Vert Clear Zone.
Hope this helps.
Namdac
