AISC Fatigue Design - Which Category?
bootlegend
289
I am looking at a bulk material storage bin and thinking about the many cycles of loading and unloading. Suppose I have simple span floor beams with a "floor" plate bolted to the top flange of the beams. What case would be appropriate for the fatigue checks on the beam at the bolt location? Table A-3.1 (15th edition) category 1.5 is for members with drilled or reamed holes but only lists two options: pretensioned bolts, with a threshold stress of 10 ksi, or empty holes with a threshold stress of 7 ksi. I'm planning on non-pretensioned bolts. I can't imagine a snug-tight bolt would be a worse condition than the open hole. Thoughts?
IMO, you don't have fatigue problem, as your loading is rather static and non-cyclic.
There's no option for non-pretensioned bolts because, in fatigue applications, pretension is really the only good bolting option. If you really have fatigue loading on the joint, then the constant stress fluctuation/reversals are going to loosen a bolt that isn't pretensioned (in most situations, anyway).
Do you really have a fatigue situation, though? How often will this thing be filled and emptied? What's the design service life?
The bin could see 1,000,000 cycles over 30 years. Probably wouldn't completely empty every cycle so the stress range might be less than I'm using. I was more interested in thoughts on why no snug-tight option was listed. I think phamENG has it. I'm not using the bolts to carry the cyclical load in this case (except to brace the beam flange which I don't want the bolts to loosen for that either).
Thanks!
Is this scenario really a stress reversal from tension to compressive stresses though. Sounds more like a stress range possibly wholly in either the tension or compression range if emptying/filling over time. My understanding of fatigue is you predominantly need a stress reversal over and above the minimum values for consideration and a minimum number of cycles over some limit.
Edit - By stress reversal I mean cycles into the tension and compression stress ranges.
bootlegend - be careful. If this bin is going to vibrate a lot, pretension may still be a good idea as the snug tight nuts could still back off under high frequency vibrations.
Agent - as I understand it, cycles across the T/C line are the worst case, but even oscillations within tension or compression can still induce a fatigue failure if the magnitude of the stress variation is high enough.
