If over, I think, 40 gallons then darcy weisbach method must be used. You'll have to reference the temperature expected, the density of the water/anti freeze mix, viscosity (centipoise) at that temperature, etc in the calculation.
Antifreeze can really make a system unworkable at a low temperature, especially a larger system or loop depending on the mixture ratios.
